I am looking for some references to design a switched capacitor dc-dc converter, however I could hardly find any reference online.
I am aware that the design method depends on the actual topology of the converter but, are there any guidelines for anyone topology, say I am looking for series parallel step down topology.
Through design procedure I want to find the output capacitor value along with fly capacitors to support given output current and voltage ripple.
I could only manage to get general recommendations from TI LM2770, where it's recommended to use Cfly= 0.1 Co and Co recommended is 10 uF.
Please help to come up with design procedure to meet design specs such as switching frequency, output current, output ripple, efficiency etc. Any references is much appreciated.
As stated in the datasheet there's no formula or approximation for that. All you can do is to read the test results and waveforms of the test circuits and decide what to use. Apparently, for most of the applications with that IC, C1 = 1uF and Cin = Cout = C2 = 10 uF should be alright. \$\endgroup\$
