During a test of a BJT totem pole driver I noticed that smoke began to come from my circuit. I made the assumption that it was from the BJT as the input current began to slowly climb - indicating thermal runaway. I reduced the frequency and it seems that the BJT again seems to work fine. However, the input power to the circuit seems to be somewhat higher than what is usual.
My question is, as a BJT begins to enter thermal runaway, is it basically dead and worth replacing? The power dissipation is still constant at low frequency, but as frequency climbs, the thermal runaway starts again.
Is there anything in particular experiences during a thermal runaway that could permanently damage the device in regards to the power dissipation it consumes, while it seemingly maintaining good performance at certain conditions?
I plan to replace the parts on Monday and run the tests again to see it this is the case, but I wanted a bit of a sanity check first.
Best, Jven
