I designed a board that uses the RP2040 Pico for its ADC and I/O.
To improve the ADC of RP2040 I wanted to use an external reference. In the past, for other projects, I used as external reference a LT1019 (a shunt or series reference) and it worked well.
For this new design, I decided to use a precision series reference (REF5030) and I overlooked the datasheet which specified you should use a shunt reference... (as a LM4040).
Circuit series reference -> RP2040 Pico
When I switched ON the board, I started to get a lot of noise at the output of the REF5030. By adding a resistor in series (200 ohm) to the output of the REF5030, the instability at the output of the REF5030 decrease to 20 mV (from 100 mV).
I went through the circuits board provided in the RP2040 Pico datasheet, in the appendix at p.24 I got the wiring of the ADC_VREF.
Since it will be difficult (and expensive) to re-build the board that I made in a reasonable amount of time, I was wondering if I could change R9 (1 ohm) on the Pico board (see image attached) to an higher value resistor.
Resistor on the RP2040 board
It should be okay with 1Ω according to the reference datasheet, assuming a ceramic capacitor.
However, it's not clear what your actual schematic is. If you have C14 as shown in the top schematic, you should remove that or replace it with a tantalum capacitor.
  • \$\begingroup\$ Hi Spehro, thank you for your message. In my schematic, I have a ceramic capacitor of 1uF (C14) at the output of the REF5030, as recomended in the datasheet of the REF5030. While I could see that removing the capacitor might remove the oscillation, why would a tantalum capacitor be a better? \$\endgroup\$
    – Kostr
    Aug 19, 2023 at 19:19
  • \$\begingroup\$ Hi Spehro, thank you for your message. Good point, the capacitor should have low ESR to maintain stability. I planned to get a low ESR capacitor, but while ordering I forgot about. \$\endgroup\$
    – Kostr
    Aug 19, 2023 at 19:29
    \$\begingroup\$ Not just low ESR, ESR in the range of 1.0 to 1.5Ω as per the datasheet. C14 may have too low ESR if it is a ceramic type so it could cause oscillation or ringing. \$\endgroup\$ Aug 20, 2023 at 3:29
