Here is an image of the connector and the crimp terminal I am trying to find out. The part code for the connector is 10112284-002LF from FCI.
  • \$\begingroup\$ Please provide dimensions \$\endgroup\$
    – Voltage Spike
    Aug 22, 2023 at 15:40
The connector is from the Amphenol (FCI) Pwr Profile I/O family. The photo shows the cable connector end which can be found under the P/N that you gave, 10112284-002LF. It doesn't appear that Amphenol sells just the housing alone or just the crimp terminal alone, you have to buy them both in a kit (which is what that P/N has -- a bottom and top cover and two crimps). Seems to be a pretty specialty part, since none of the major distributors have them. Might need to go directly to Amphenol on this one.
