I've been working through the problems in a game based around building a Turing Complete machine.
One of the final problems asks you to implement the call and return instructions. This makes it seem like they're part of the ISA and need to be implemented in the microarchitecture.
Is this accurate? Or are call and return usually built from simpler instructions?
    \$\begingroup\$ "Usually" shifted over time. \$\endgroup\$
    – greybeard
    Aug 23, 2023 at 9:24
  • 4
    \$\begingroup\$ @SimonRichter We're talking electronics here, not art. Everything <1990 is ancient and everything <2000 is very old. Meaning that architectures like AVR and PIC are very much outdated and the general trend to move away from these started around 2005-2010. \$\endgroup\$
    – Lundin
    Aug 23, 2023 at 12:00
    \$\begingroup\$ yeah, x86 really kind of broke our progress machine on architectures. Many of the original instructions are still implemented (in microcode) on modern x86s, but really, if your instruction is not super common (jump, compare (not) equal, …) and was there before 2000, chances are your modern program will be much faster if it uses other, later added instructions, even on x86. (There's C string optimized functions for doing things like finding the length of a string in x86. The hell.) \$\endgroup\$ Aug 24, 2023 at 0:10
    \$\begingroup\$ @Connoryes, x86 carries around 40 yeara of baggage. Because it's hard to built a good modern microprocessor based on architecture that seemed like a good idea in the 1980s, much of this baggage is rather slowly emulated in complex microcode. If you're a compiler developer, you have to very carefully read the Intel manuals for each new processor generation, try and benchmark a lot of things to generate good machine code, which hopefully makes good use of the modern hardware. X86 very clearly is a giant ISA, full of historical compromise, and not very consistent. I surely wouldn't implement it. \$\endgroup\$ Aug 24, 2023 at 8:05
    \$\begingroup\$ @Connor I agree with Marcus; if you're implementing something and can choose, RISC-V is probably the state of the art choice. For just studying, the various iterations of ARM are a good choice. MIPS/68k are simpler but older. The various proprietary microcontroller instruction sets are .. also weird. \$\endgroup\$
    – pjc50
    Aug 24, 2023 at 9:40
The short answer for any reasonable definition of modern is "yes". Even little things like PIC16 have call and return. ARM, for historical reasons, spells CALL as "bl" and RETURN as "mov pc, lr".
Given how frequently that functionality is needed, there's no sense in forcing the programmer to build it from more complex instructions, and there are serious problems if your processor supports interrupts and CALL/RETURN aren't atomic. You basically must have an atomic "return from interrupt" instruction unless you want problems when an interrupt arrives in the middle of returning from an interrupt.
    \$\begingroup\$ Some instruction sets use "JSR" (Jump to Subroutine) in place of "CALL" (same fucntion, different name...) \$\endgroup\$ Aug 23, 2023 at 15:50
    \$\begingroup\$ There are many ways to return on ARM, especially if THUMB is involved. Depending on the compilation environment, one may also see bx lr or pop {pc}, or pop {r3} + bx r3 etc., or even equivalents implemented with ldm or ldr. Fundamentally they either "branch with exchange" (which allows for switching between ARM and THUMB modes) to some register, or else explicitly store a value in the program counter. \$\endgroup\$ Aug 23, 2023 at 19:02
    \$\begingroup\$ I agree with this answer, but I'm not sure "serious problems" is quite the right language to use, more that it makes things more complicated than "modern" programming tends to have to deal with. \$\endgroup\$
    – Ben Burns
    Aug 23, 2023 at 20:24
    \$\begingroup\$ @Connor yes, it does. Arm is just a family of different ISAs, and a huge family if different microarchitectures, so not all have the same amount of memory and CPU state handling, but on anything remotely modern that's called arm, you get switchable stack pointers, to make things like context switching easier. \$\endgroup\$ Aug 24, 2023 at 8:09
    \$\begingroup\$ Again, what you call a stack is more or less an interpretation of what you can use an address register for, so be careful when mixing software concepts with hardware concepts. In some architectures, you can build a concept like "stack" easily from hardware instructions, or there is a one-to-one correspondence, in others you just program that concept in less specialized instructions. Arm is typically more in the latter camp. When it comes to stack, that's fairly cleanly representable in thumb2 instructions. \$\endgroup\$ Aug 24, 2023 at 8:11
