I have 64 digital hall effect sensors with open drain outputs (A3144), and would like to read their outputs with an MCU. Is there a simple way to multiplex these sensors to limit the number of IOs needed? Reading bandwidth is low.
My thought is as follows:
Arrange the sensors in a 8x8 matrix, shorting the outputs of every row, and the grounds of every column. Interrupt the power supply on the GND side with a mosfet, and cycle one column at a time like conventional multiplexing. The unsupplied sensors will see their GND go up to VCC and won't be able to pull down the line even if their output is active.
I have some concerns:
- in case the active sensor in the row is low, the other sensors will see -5V on their outputs wrt their GND. Do I need a diode in series with each individual output for protection?
- is it a bad idea to repeatedly power cycle the sensors at moderate frequency? (no startup time is specified in the datasheet
