"If the voltage potential from VBB to VOUT exceeds the clamping voltage, the power FET will allow current to flow from VBB to VOUT (path 3)."
https://www.ti.com/lit/ds/symlink/tps1hb50-q1.pdf?HQS=dis-mous-null-mousermode-dsf-pf-null-wwe&ts=1692829680936
If the FET switches off an inductive load, the inductor current will cause the Vout pin to start dropping, increasing the voltage across the FET. If it reaches the clamp voltage, in order to prevent damage to the FET, it will turn back on to keep the voltage within safe limits.
