I'm building a robot that's running on a 12S, 10400 MAh LiPo. Because of obvious reasons, the system requires a protection circuit. My question is, can I purchase this 13S (which I suppose works with lower S values too) 100A Li-lon BMS from Daly and use it as protection for my circuit? It is made for Li-Ion... So will it work?
All I need is to have an adjustable cut-off voltage, e.g. the battery goes below 3.6 or 3.7V/cell, it disconnects it from the system. The expected current draw is 70A (yes, the robot will operate for just a couple of minutes)
