I have a small electronic device that seems to have suffered from a voltage surge or similar bad event (ESD?).
I think it is a DC/DC converter but I couldn't find anything with the markings that are hard to read/take a picture of: W8BFZ?
PCB picture
It has 6 pins, 1 bottom left, the 2 is visibly ground and the others are connected to external lump elements. The pin 5 seems to have exploded.
I found a similar device called MP2459 and the pinout matches (2=GND, 5=IN).
Can someone identify more precisely the chip ID?
Edit: forgot to post the corpse:
aftermath of whatever event caused destruction
  • \$\begingroup\$ Can you provide package dimensions? \$\endgroup\$
    – Voltage Spike
    Aug 26, 2023 at 1:31
  • \$\begingroup\$ I don't have tools to measure but I'm pretty sure the cap on the left is 0201. That should help gauge the size. Does that answer? Sorry I can't do better \$\endgroup\$ Aug 26, 2023 at 2:15
It's a Silergy Corp SY8120B1ABC step down converter.
(Source: lcsc.com)
