I want to incorporate this inductor: https://www.lcsc.com/product-detail/Inductors-SMD_SHOU-HAN-CYH127-150UH_C2929506.html in my project.
Datasheet it here: https://datasheet.lcsc.com/lcsc/2201121430_SHOU-HAN-CYH127-150UH_C2929506.pdf
According to the website, it has an SMD,12.3x12.3mm package. Searching the Kicad's Inductor SMD footprint library, nothing matches with the string 12.3x12.3.
Does someone has in mind which footprint matches this inductor?
Inductors are probably the most varied components in SMD packages. It is pointless to search for the exact match by package size in most cases.
Instead check the datasheet for recommended pad layout, especially the distance between the pads. Then simply browse through available packages and find the best fit.
If there is nothing suitable, then make a copy of the closest available and modify it to datasheet dimensions. It only takes couple minutes after all.
