I'm attempting to build a soft-start motor controller for a Ryobi 40 V, 16 inch electric mower (to replace a broken factory unit; unit is potted so I can't see/access the guts). Only details I have on the motor are:
- 40 V, 3800 RPM
- DC resistance is something less than 1 Ω (my meter not so accurate at sub-ohm values
- When attempting to power motor directly from the 40 V battery, enough current flowed for long enough to blow the 40 A slo-blo fuse in the battery
- Don't know inductance, but will try to run some tests to look at LR time constant to get a rough idea
As per draft schematic shown, I plan to use an Arduino Uno to generate a PWM signal to drive 4 IRF3205PBF MOSFETs. No idea if I need 4 MOSFETs, but on the 20 inch version of this mower, the control board has 6 power MOSFETs, so hoping 4 will do the trick. The Arduino will also handle the safety logic (not shown in the schematic) of when to power up the mower based on the button and bar on the mower handle.
Questions:
What MOSFET driver to use? Thinking of Texas Instruments UCC27424. Is there a better controller choice?
What flyback diode to use? Thinking of using Microchip Tech APT30S20BG Schottky (200 V, 45 A continuous, 320 A non-repetitive). Is there a better diode choice?
I'm ignorant as to frequency and duty cycle of the PWM signal (maybe these questions can't be answered without knowing detailed electrical specs of the motor?): a) Should the percentage-on-time be based on the LR time constant of the motor (which I don't know)? b) Should I start with a small percentage-on-time, and slowly increase until it is on 100% of the time?
Out of paranoia and ignorance, I'm thinking of adding an additional MOSFET (shown on the schematic) to power the motor for a few seconds using a ~50 Ω high wattage resistor (I have an old clunky ohmite resistor in my junkbox). This MOSFET would be turned on (via the Arduino) a couple seconds before the PWM MOSFETs in order to build up a little back EMF from the motor. Is this a good/bad/stupid/useless idea?
Thanks for any advice.
