6
For a fictional text, I was wondering whether, and how, electronic components are affected by oxygen and moisture in the air, natural background radiation etc, over the course of years or decades.
Silicon, for example, is usually protected against corrosion by passivation. A lot of plasticizers slowly evaporate or decompose, so plastics become brittle over time. I'm not sure about copper, I think it might be fine as long as it's dry enough. Another source of degradation might be temperature stress (freezing / thawing) leading to broken connections.
I realize this is a pretty broad question, but I was hoping there are some typical examples, maybe there's typical storage requirements for electronic equipment or typical failures of components that have been in, say, a mountain hut for too long. I would guess that there might be some sources from the cold war on topics like that (think bunkers).
    \$\begingroup\$ If they are unused, it hardly matters! If the equipment is intended for some emergency, then the equipment has to tested regularly and maintained. E.g. a fire alarm that hasn't been activated in 30 years can hardly be relied upon. The bad "agers" in electronics are electrolytic capacitors, and the commonly repeated estimates on their age range from 15 to 25 years (and in debates of electrolytic cap aging, someone always comes up with an example of some perfectly working 30+ year old device with original electrolytics.) \$\endgroup\$
    – Kaz
    Commented May 2, 2013 at 16:13
6
It's worth distinguishing between unused never-assembled components and unused assembled devices, and consumer versus military.
Quite a lot of components specify an unassembled shelf life that's suprisingly short. This is mostly because water gets into the packaging, which will boil and explode during soldering. So you might have to carefully dessicate components before use. There's a lot of "new old stock" floating around in various inventories, some of it forgotten.
In assembled devices, batteries are going to be the first thing to go. Very few have shelf lives above 10 years. Some missiles have molten salt batteries as a way round this.
Electrolytic capacitors are next to go. People restoring old electronics will often replace all the electrolytic capacitors before even trying to power it on.
Beyond that, corrosion is the main enemy. If it's sealed against corrosion, it will last an astonishingly long time. Epoxy chip packages are slightly less durable than the ceramic ones.
There's a small cottage industry in recovering Nixie tubes from old electronics from the 1950-1970 period and reusing them for their decorative properties in clocks.
Semiconductor components are stored in a dry, oxygen free atmosphere if long term storage is a concern. This can be accomplished by a Nitrogen purge or with moisture and oxygen absorbing materials. It's about package moisture ingress and oxidation of leads. It can be dangerous as these are potentially suffocating environments for people so detectors and warning systems need to be in place.
Sometimes semiconductor packages will have nitrogen or argon purges before final top lid assembly and seal.
Gamma and particle irradiation can be a concern for certain types of devices. Typically an ionizing radiation hit might disrupt an active circuit (SEU - Single Event Upset) during operation, but when non-operational it would have to do lasting damage which is less common close to the earth's surface. Typically shielding is not necessary. But there are type of devices that will have decreased performance if they are shipped via airplane (some types of image sensors for example).
