I have old PCB Altium design files and Gerber files. I want to cross check Gerbers with design files. However I'm trying by visually checking, but I know that's not a smart technique to do that. Is there any smart and optimized technique for cross-checking?
    \$\begingroup\$ You could export the design files as Gerbers, then use a Gerber comparison tool. \$\endgroup\$
    – JYelton
    Aug 29, 2023 at 5:02
    \$\begingroup\$ Altium has an online Gerber compare tool at altium.com/gerber-compare \$\endgroup\$
    – user85471
    Aug 29, 2023 at 5:24
  • \$\begingroup\$ @JYelton can you suggest any free camparison tool. \$\endgroup\$ Aug 29, 2023 at 6:01
    \$\begingroup\$ @BhushanWaghe I don't know of any free ones, at one time I used a non-free predecessor to Numerical Innovations' FAB 3000. (This is why I posted as a comment instead of an answer.) \$\endgroup\$
    – JYelton
    Aug 29, 2023 at 6:12
  • \$\begingroup\$ Thank you JYelton \$\endgroup\$ Aug 29, 2023 at 8:23
I use BeyondCompare from Scooter SW because we are not allowed to upload our design to any online storage including Altium.
As BeyondCompare can compare pictures pixelwise and mark all differences you can directly use this to compare the Gerber files of a PCB layer by layer. The Standard version for about $35,- is enough
For both PCB Versions: 1. Open the Gerber files in Altium Designer CAMtastic 2. Enable only the Layer of interest (single layer mode) 3. File -> export -> Bitmap 4. Mark the whole PCB (let mouse click) 5. End marking mode via right mouse click 6. Select DPI=1000 and Color scheme = monochrome 7. Save
Compare them in Beyond Compare Choose the Pixel tolerance as you like
Use any Gerber viewer, load both designs and give similar layers, eg GTL on both designs, different colors. You will see the areas where the layers differ, since the colors won't mix there.
