I'm designing a device powered by two Li-ions in series and I'm struggling with the charging and protection of the batteries. One of the requirements is to avoid battery packs, the individual cells need to be interchangeable. The load current can reach 6 Amps.
The idea is to use the BQ25887 charger with integrated balancer and S-82C2A protection circuit.
The issue I'm hitting here is the reverse polarity protection. Any or both cells could be inserted in reversed position, damaging the protection circuit and/or the charger.
The to back-to-back mosfets required by the S-82C2A already introduce quite a lot of series resistance (2 milliohm Rdson - 150 mW losses), adding more MOSFETs would increase the losses even more, not speaking about another single point of failure.
Is there a simple way to protect the circuit from the reverse oriented cells I'm missing? Or maybe a different 2s overvoltage/undervoltage/overcurrent Li-ion protection IC that could survive the reverse polarity event?
Edit
I'm thinking, I could place P-MOS between bat1+ and VDD and another between bat2+ and VC. If the battery got inserted in a reverse polarity, the P-MOS would close, protecting the IC. And the IC would not be powered, the FET1 and FET2 would remain closed, protecting the connected circuit and the charger.
And as almost no current would flow through the P-MOS transistors, the efficiency would be unaffected.
