6
I am using my Arduino Uno as a programmer to program my ATtiny85. I uploaded the ArduinoISP sketch to my Uno. I double checked my wiring, did some googling, but I still can't figure out why I get this error ...
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x11
avrdude: stk500_cmd(): programmer is out of sync
... when I run this command:
sudo avrdude -p t85 -c arduino -P /dev/ttyACM0 -b 19200 -U flash:w:src.hex\
Then I checked to see if the ATtiny was responding, I ran this command:
sudo avrdude -P /dev/ttyACM0 -p t85 -b 19200 -c avrisp -v
The results were successful.
EDIT:
Here are the time stamps (just in case):
15:24:29.502445729 E:
15:24:29.623628385 E: avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny85
15:24:29.761744829 E: avrdude: AVR device initialized and ready to accept instructions
15:24:29.766251405 E:
15:24:29.812810614 E: Reading | ################################################## | 100% 0.05s
15:24:29.821187588 E:
15:24:29.825324777 E: avrdude: Device signature = 0x1e930b
15:24:30.171341329 E: avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
15:24:30.180631410 E: To disable this feature, specify the -D option.
15:24:30.334997131 E: avrdude: erasing chip
15:24:30.495926604 E: avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny85
15:24:30.632387526 E: avrdude: reading input file "src.hex"
15:24:30.637210000 E: avrdude: input file src.hex auto detected as Intel Hex
15:24:30.641710226 E: avrdude: writing flash (98 bytes):
15:24:30.645806835 E:
15:24:30.712364458 E: Writing |
15:24:30.718291473 E: avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x11
15:24:30.752474103 E: avrdude: stk500_cmd(): programmer is out of sync
15:24:30.827210626 I: Finished with exitcode 1
I can't seem to figure out what is wrong. Any suggestions?
  • \$\begingroup\$ Why do you keep changing the -c setting? \$\endgroup\$ May 2, 2013 at 17:55
  • \$\begingroup\$ According to the programmers.txt file in the Arduino IDE, the -c setting should be “stk500v1”, although “arduino” is very similar. \$\endgroup\$ May 2, 2013 at 17:57
  • \$\begingroup\$ @ChrisStratton It doesn't matter if it's arduino or avrisp, they're the same thing. \$\endgroup\$
    – user151324
    May 2, 2013 at 18:05
  • \$\begingroup\$ @microtherion I tried stk500v1 instead of arduino, the same thing happened... \$\endgroup\$
    – user151324
    May 2, 2013 at 18:08
  • \$\begingroup\$ I use the ISP sketch on an Uno without anti-reset components, -cstk500v1 and have no problem programm attiny85's though I'm also using -pattiny85 as the part identifier, using an avrdude config that came with an arduino installation (and specifying the path to that config with the -C option). \$\endgroup\$ May 2, 2013 at 18:09
7 Answers 7
I solved exactly the same problem by upgrading arduino IDE from 1.00 to 1.05 from http://code.google.com/p/arduino/downloads/list
This version of arduino IDE contains new version of ArduinoISP sketch.
I was getting this error with my Arduino Uno
I had a protoshield connected and when I disconnected the protoshield everything started working fine.
EDIT
After some additional trouble shooting I found that it wasn't the protoshield, it was that the protoshield didn't have TX / RX marked for Digital PWM pins 0 & 1. Once I unplugged cables from 0(tx) & 1(rx) that resolved my issue.
I also had the problem: "avrdude: stk500_paged_load(): (a) protocol error, expect=0x14, resp=0x00. avrdude: stk500_cmd(): programmer is out of sync".
Later given up. Then I used another USB cable (proper) instead of a thin USB cable supplied with a Pololu ISP for something else and I realized the cable I used with the Arduino Nano may be of inferior quality. Changed the cable and - all my problems are solved!
I had a long USB cable (10') connected to a powered 9-port usb hub.
Connecting directly to my mac fixed this issue immediately.
I've noticed that, depending on its mood, connecting directly to the machine can fix upload issues.
In my case installing "AVR-GCC Toolchain" via Homebrew fixed all this issues.
All necessary details here: http://maxembedded.com/2015/06/setting-up-avr-gcc-toolchain-on-linux-and-mac-os-x/
Disconnect all connections on your arduino board device, and try to upload the code to your arduino board. i solve this problem. There may be one of your problematic hardware, connected to your arduino board.
Yeah.. Then I disconnected all the connections in Bluetooth ....after I compiled the program then I connected my Bluetooth to the Ardiuno uno.... Then I didn't get any error.
