circuit Given this circuit I’m asked to determine the transfer function from \$V_i\$ to \$V_o\$, but there are no answers given and my result disagrees with my earlier DC analysis.
I think think the first “stage” is just a voltage follower. By superposition, it’s easy to show that \$V_o’ = V_i\$ (though I'm unsure whether I'm allowed to split \$V_i\$ like that):
For the second stage
Since \$A_2\$ is ideal, there is no current through \$C_2 \parallel R_5\$ so \$0V\$ drop across it, and the inverting port follows the non-inverting one, thus there is \$-V_i\$ across \$R_3\$, and by Ohm's law \$i = -\frac{V_i}{R_3}\$ running through it.
After which I did KVL (red arrows): $$ V_o + i(R_4 \parallel C_3) + V_i = 0\\ V_o -\frac{V_i}{R_3}(R_4 \parallel C_3) + V_i = 0\\ V_o + V_i[1 - \frac{1}{R_3}(R_4 \parallel C_3)] = 0\\ V_o = - V_i[1 - \frac{1}{R_3}(R_4 \parallel C_3)]\\ \frac{V_o}{V_i} = H(s) = \frac{1}{R_3}(R_4 \parallel C_3) - 1\\ H(s) = \frac{1}{R_3} \frac{\frac{R_4}{sC_3}}{R_4 + \frac{1}{sC_3}} - 1 = \frac{1}{R_3} \frac{R_4}{sR_4C_3 + 1} - 1\\ H(s) = \frac{R_4 - sR_3R_4C_3 - R_3}{sR_3R_4C_3 + R_3}\\ H(0) = \frac{R_4 - R_3}{R_3}\\ $$
However, I've found earlier through DC analysis (\$R_1, R_2, (C_2 \parallel R_5)\$ are short, \$C_3, C_1\$ are open) that the DC-gain should be \$1 + \frac{R_4}{R_3}\$.
I'm not even sure where to look to find my mistake.
  • \$\begingroup\$ Are you certain that \$i=-\frac{V_i}{R_3}\$. Also check the polarities for KVL voltages. \$\endgroup\$
    – RussellH
    Sep 3 at 17:18
  • \$\begingroup\$ Aha, spotted it, it's the very first line in the KVL, it's supposed to be - V_i. I'm not sure what the correct procedure here is, should I answer it myself and pick that answer? \$\endgroup\$
    – Learath2
    Sep 3 at 21:00
    \$\begingroup\$ @Learath2 Yes, just write your own answer and select it. Are you supposed to account for input bias currents? Speed-up C2, as well? \$\endgroup\$ Sep 3 at 23:08
  • \$\begingroup\$ I see. Ideal op-amps so no input bias currents. What do you mean by "Speed-up C2"? \$\endgroup\$
    – Learath2
    Sep 4 at 12:33
The first line doing the KVL was wrong, leading to the wrong result. It's supposed to be $$ V_o + i(R_4 \parallel C_3) - V_i = 0 $$
If opamps are ideal, R1, R2, R5 play no role.
A1 is a buffer indeed. Note that due to virtual ground, no current flows through R6, and thus none through R7. So vin is buffered to vout.
A2 is a non-inverting stage, with gain G2 = 1 + R4/R3 = 1 + 27/9 = 4.
So, the TF(0) = 1 * 4. Which agrees with what you found before.
  • \$\begingroup\$ We seem to agree that the DC-Gain should be 4, but at the very end I find H(0) = 2, so I must have made a mistake somewhere. \$\endgroup\$
    – Learath2
    Sep 3 at 20:51
  • \$\begingroup\$ Does the first-stage buffer have any practical use (compared to the "standard" op amp buffer) or is it just an academic problem? \$\endgroup\$
    – Hyp
    Sep 4 at 10:53
  • \$\begingroup\$ @Hyp I'm not completely sure as I'm just learning these right now, but C1 makes this a Miller Integrator (a less than perfect one due to R7). So it does change the frequency response, though not sure what one might use it for :D \$\endgroup\$
    – Learath2
    Sep 4 at 12:36
  • \$\begingroup\$ @Hyp: some resistors may be employed for bias currents comepensations, which are not mentioned here though. So I'd say they're just there to test your knowledge. \$\endgroup\$
    – edmz
    Sep 4 at 17:27
  • \$\begingroup\$ @Learath2: that's not an integrator. Input current is not being integrated. \$\endgroup\$
    – edmz
    Sep 4 at 17:28
