Can an antenna signal (from an antenna cable) be transfered along with an ethernet signal through a category 5 cable? Will I lose too much signal quality?
Antenna specification:
Digital indoor antenna DVB-T
For terrestrial, digital signals (UHF/VHF/FM and DAB-receiving).
Frequency range:
    VHF: 174-230 MHz
    UHF: 470-862 MHz
Amplification:
    VHF/UHF: 28 dB
Powered by included AC adapter 230V or directly via DVB-T 5V/40 mA (set top box/digital TV).
RF cable:
    IEC to F connector, 1,5 m
Size:
    Width:  115 mm
    Depth:   35 mm
    Height: 180 mm
The antenna manufacturer is Biltema. I think the antenna model is being discontinued by the manufacturer. Biltema has released a newer model, almost (at least visually) identical to the one I have, but for some reason you can't find it in the online catalog.
  • \$\begingroup\$ According to wikipedia (en.wikipedia.org/wiki/Category_5_cable) CAT5 has a characteristic impedance of 100ohm. While I believe your UHF/VHF etc will required a 50 Ohm impedance. Better to find a cable that's designed for it if you need an extension. \$\endgroup\$
    – Mark B
    May 4, 2013 at 21:01
What kind of antenna? What length?
You're going to need to provide a lot more information, but the short answer is probably no. Anything above a few Mhz, that is not specially conditioned, cannot be fed over a CAT-5 cable.
  • \$\begingroup\$ As a side note, there's also the question of interference from the signal. \$\endgroup\$ May 3, 2013 at 8:40
