I'm using a Würth Elektronik 7498210220A jack (datasheet) and I need to add ESD protection to TD and RD lines of this Ethernet connector (with integrated magnetics).
Application of this Ethernet adapter is industrial.
I've found these products below.
Question: What advantages and disadvantages do these different layouts have?
Semtech RCLAMP3354S.TCT (details)
Semtech RClamp3354S pinout
Image source: Semtech RClamp3354S datasheet
Semtech RCLAMP2502L.TBT (details)
Semtech RClamp2502L pinout
Image source: Semtech RClamp2502L datasheet
Semtech RCLAMP3374N.TCT (details)
Semtech RClamp3374N pinout
Image source: Semtech RClamp3374N datasheet
Littelfuse SLVU2.8-4BTG (details)
Littelfuse SLVU2.8-4BTG pinout
Image source: Littelfuse SLVU2.8-4BTG datasheet
  • \$\begingroup\$ All but the last one limit to a certain voltage wrt ground, whereas the last one only limits differential voltage between two pins, so you'd have to connect ground to 4 pins. \$\endgroup\$
    – tobalt
    Sep 6 at 5:32
