Do corner-grounded deltas exist outside of USA? If yes, where?
Where do you find information about this? Is there an IEC standard that dictates which transformers exist where?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityDo corner-grounded deltas exist outside of USA? If yes, where?
By my experience, tertiary windings with on single point grounded are used all around the world. IEEE C57.158-2017 provides recommendations for such practice (if you look to the participants list, there people from many different countries).
I live in Brazil, and I can say that here it's almost omnipresent in the entire transmission system.
Note: this single point grounded deltas are used in medium voltage (like between 15 and 36kV). Regarding low voltage (i.e., <1kV), I never saw any of it here.
I know by experience it exists in Uruguay, and I can even say they sometimes even change the grounding point. I noticed it once when mounting an LED lamp in the backyard. Depending on which wire I chose as neutral (which isn't defined) you had a small glow when the lamp was off or not. I, of course, chose the wiring so that it didn't glow. A few months later, the operator changed the grounding and it started glowing. You have quite a variation on the electrical codes across countries. In Argentina, for example, they use star, and the neutral is tied to ground, therefore if you get a 3 phase machine the neutral will usually be connected to ground. If you plug that in in a country that doesn't do that it will trip the differential.
