What is this 6-pin IC on board?
You can see that the IC has the label X17. and we know that its a 6 pin SMD IC. You can google "X17 6 pin SOIC" and you will get the first result with the answer you are looking for.
    \$\begingroup\$ I've just tried that, and don't get actually get the Rohm IMX17, which I think is the part in question. Was this the exact search phrase you used on google, and what was the part it threw up? \$\endgroup\$
    – colintd
    Sep 11 at 9:04
The code and package fits with a Rohm IMX17 dual NPN transistor. Digikey page here.
  • \$\begingroup\$ Amazing! Would you mind sharing your methods for conducting these kinds of investigations? \$\endgroup\$ Sep 11 at 6:41
    \$\begingroup\$ There are a number of SMD code databases (a web search with thrown up several), which allow lookup on code, then you can assess the matches based on package and PCB/function. \$\endgroup\$
    – colintd
    Sep 11 at 6:54
    \$\begingroup\$ You can also look in the data sheets at placement of the printing, and also batch codes to help provide confirmation. \$\endgroup\$
    – colintd
    Sep 11 at 6:55
