I want to find the maximum aggregate I/O current supply for the MachXO3D (9400HC) breakout board to ensure that I do not damage it. All pins will be using the LVCMOS33 I/O standard. I have been up and down the datasheet for hours to no avail and I suspect that this may be something that has to be inferred using some sort of calculation, but I am currently at a total loss.
Looking in the MachXO3D Family Data Sheet (linked from the MachXO3D Enhance Secure Control Applications with Hardware Root-of-Trust and Dual Boot Capabilities documentation) there is the following note in the 3.12. sysI/O Single-Ended DC Electrical Characteristics section:
  1. For electromigration, the average DC current sourced or sinked by I/O pads between two consecutive VCCIO or GND pad connections, or between the last VCCIO or GND in an I/O bank and the end of an I/O bank, as shown in the Logic Signal Connections table (also shown as I/O grouping) shall not exceed a maximum of n * 8 mA. “n” is the number of I/O pads between the two consecutive bank VCCIO or GND connections or between the last VCCIO and GND in a bank and the end of a bank. I/O Grouping can be found in the Data Sheet Pin Tables, which can also be generated from the Lattice Diamond software.
I can't find anything else in the datasheet about the maximum aggregate I/O current supply.
