Just wondering why exactly the current is flowing in the directions depicted in the image below? It is my (rudimentary) understanding that current flows from regions of high potential to regions of low potential. In this case I imagined that the current would flow from the anode of the \$18V\$ battery to the top node and then there would be 3 courses the current could take:
- The cathode of the \$18V\$ battery
- The anode of the \$12V\$ battery
- the cathode of the \$12V\$ battery
My thinking here would be that the current would just go to the cathode of the \$18V\$ battery since that would appear to be the highest potential difference. Although, how do we know what the potential of the cathode for the \$12V\$ battery is set at? If voltage of a battery is just describing a difference between the positive and negative terminals, then couldn't it be the case that the difference between the anode of \$18V\$ battery and the cathode of the \$12V\$ battery is greater than that of the difference between terminals of the \$18V\$ battery? Which would then drive the (positive) current out of the \$18V\$ anode to the top node then down through the \$6\Omega\$ resistor to the bottom node, then through the \$4\Omega\$ resistor into the cathode of the \$12V\$ battery. Furthermore why does the current split off and go down each available path at each node? If there's one path that has the greatest potential difference I would think the current would simply take that path to the exclusion of the others.
I have italicized more specific hangups I have when viewing this diagram and thinking about circuits, more generally, but I would appreciate someone's step-by-step thought process on how to understand the general path of current in any circuit, as well. Thanks!
