Must one buy a separate ground cable in a TN-S network for earthing or can the concentric conductor be used for earthing purposes?
1 Answer
This is how a TN-S earthing system is wired: -
Image from TNS Earthing System: A Useful Guide.
If you don't have an earth wire it won't conform to the regulations.
It has to be exclusively earth and not shared with any other connection like neutral.
\$\begingroup\$ We actually took 4xNYCWY 185/95 cable. It comes with 4 conductors of 185mm2 and 1 concentric conductor of 95mm2. We had given the plan to the energy supplier but I doubt if they carefully looked. What is the purpose of concentric conductors in these cables if we cannot use them for grounding purposes? \$\endgroup\$– SmrtngySep 13 at 13:01
\$\begingroup\$ I have no idea about that cable or whether some of the conductors can be used for protective earth. I can only tell you what the standard for TN-S is. \$\endgroup\$– Andy akaSep 13 at 13:21
