Please help me to identfy this IC.
Known information:
- Marking code 6003-001 NQ97P
- Part of the battery of Fimi x8 Mini Drone
- Connected to a SC8906 charger IC
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityPlease help me to identfy this IC.
Known information:
It's probably a Sino Wealth (中颖电子) SH366003 battery management IC, which seems to be a pin compatible clone of the Texas Instruments BQxxxxx series, like the BQ28Z620.
I couldn't find a datasheet, but I've found several clues that lead to this conclusion:
6002
marking. The markings are not exactly the same, but the image is a rendering so we can't be sure how accurate it is to the real chip. I couldn't find a photo.The same manufacturer also sells a battery chip with the part number SH366003. This means it would probably be marked 6003
. Sadly there is little public information available and I can't find a datasheet.
There is a test report for a "Rechareable Li-ion Polymer Battery". That mentions that the IC is used in the product. The pictures are too low resolution to discern any markings, but it has a (equally low res) schematic that shows the pinout and tells us the package: DFN12-L(4*2.5) which seems consistent with the IC in question.
Number | Name |
1 | VSS |
2 | SRN |
3 | SRP |
4 | TS1 |
5 | SCL |
6 | SDA |
7 | DSG |
8 | PACK |
9 | CHG |
10 | PBI |
11 | VC2 |
12 | VC1 |
