What is the purpose of the 1000 µF and 0.22 µF capacitors at the input of 7805 voltage regulator?
Input to these capacitors is the rectified pulsating DC voltage. What will be the shape of this voltage wave form at the output of these capacitors or the input of IC 7805 voltage regulator?
  • \$\begingroup\$ Without a capacitor after the rectifier the input voltage to the 7805 would go down to almost zero volts in between each half wave, so you need a storage cap to keep the voltage high enough for the LDO to regulate the output. \$\endgroup\$
    – jusaca
    Sep 15 at 6:48
If we consider ideal diodes in the bridge rectifier without the capacitors, the voltage at the input of the 7805 would be the absolute value of a sine of 50Hz (i.e. positive parts of a sine wave repeating at 100Hz).
So 100 times per second the voltage is 0V, and the 7805 hasn't any voltage at the input, so it can't generate voltage at the output. Very bad if you want a regulated 5V at the output.
If you now add a large value capacitor (the 1000µF electrolytic capacitor), then it will be charged when the half sine is at its maximum, but only discharge very slowly when the half sine is near zero (it can't discharge through the diodes, so it is just discharging through the 7805).
This way, if the capacitor is big enough, it can provide the current needed by the 7805 while the half sine voltage is too low.
You can use a very large capacitor to get a nearly constant voltage, or somewhat smaller one so that the voltage will decrease on each half-cycle until just above the minimum voltage needed by the 7805 to keep delivering 5V.
The second solution is cheaper (smaller capacitor), the first one might provide a little bit cleaner regulated 5V (it depends on the quality of the regulator: some are quite sensible at changes in input voltage (a few %), others are extremely stable.
For the 0.22µF, its goal is different: it's not so much about storing a lot of energy, but rather about filtering high frequencies/allowing rapid adaptations to change in current demand. Electrolytic capacitors are notoriously bad at high frequency (above 100kHz-1MHz), so often we add a small ceramic capacitor in parallel, that stores less energy, but is very good at high frequencies.
  • \$\begingroup\$ Nicely explained. Can you please add the formula to calculate peak to peak ripple voltage and the formula to calculate Vdc to your answer for the input to the ic 7805 voltage regulator? \$\endgroup\$
    – Alex
    Sep 15 at 7:12
    \$\begingroup\$ "The second solution is cheaper (smaller capacitor), the second one might provide a little bit cleaner regulated 5V" - Did you mean to say that a smaller electrolytic capacitor (in place of the 1000uF one) might give a "cleaner" or better regulated 5V on the regulator's output? Also, the smaller capacitors next to the 7805 are there to both improve transient response AND to prevent the 7805 from oscillating since it works like a high-speed amplifier with negative feedback and can start oscillating at up to a few MHz. Otherwise, a nice explanation; I've only fixed some spelling and grammar. \$\endgroup\$ Sep 15 at 7:52
  • \$\begingroup\$ thanks, I corrected my mistake (it's the 1st solution (ie bigger capacitor) that will give cleaner output) \$\endgroup\$
    – Sandro
    Sep 15 at 7:59
As noted in the comments,without the larger cap, the input voltage to the regulator will track the rectified half-cycles, and this (minus the voltage drop) will appear at the output. This is very unlikely to be what you are seeking.
The non-polar smaller cap will typically have a lower ESR than the bulk electrolytic, and improves the transient response of the regulator.
  • \$\begingroup\$ Can you please add the formula to calculate peak to peak ripple voltage and the formula to calculate Vdc to your answer for the input to the ic 7805 voltage regulator? \$\endgroup\$
    – Alex
    Sep 15 at 7:30
  • \$\begingroup\$ The link provided in comments above electronics.stackexchange.com/questions/73863/… has the analysis you need. \$\endgroup\$
    – colintd
    Sep 15 at 8:01
