I've seen a similar question asked earlier here: How do I bias an AC signal for sampling?
However, I have a 3 different circuits and I am not sure which one works best!
I have: +-2V AC signal of varying frequency (5hz to 10kHz). It is biased around 0V.
Objective: Shunt this signal from 0V to 3V, so the output is 1 to 5V signal (the same +-2V just biased around 3V) like demonstrated here:
Desirable outcome
Solution 1: Single Non-inverting Unity gain Op-Amps Here I cheated a little bit by increasing the AC signal from +-2v to +-4V, because the summing amp in this case forms a voltage divider Non-inverting Unity gain Op amp
Simulation: Transient and AC enter image description here
Solution 2: Two Inverting Unity gain Op-Amp in series By adding 2 inverting op amp in series, we can add to signals without "cheating" and scaling the input signals. 2 inverting op amps
Simulation: Transient and AC inverting op amps sim
Solution 3: Three Non-Inverting Unity gain Op-Amps Why? Well, the AC signal source has some impedance, so to avoid any discrepancies on the summing op amp input, I thought it would be logical to put both the AC and DC components through unity gain buffers first... enter image description here
All three circuits work and the output signal is in fact 1 to 5V in all three cases. Which solution is the best?
I would say the first one, though a typically used solution is my schematic below.
The other two are unnecessary complications
All you have to do is use a non-inverting buffer/voltage follower with a DC voltage divider on its input for centering the virtual ground level (of the AC signal) and place a capacitor on its input to separate the DC components between AC signal generator and the buffer input, like this:
    \$\begingroup\$ Perfect, thank you so much! I take it as with this approach impedance matching would not be a problem? If for example the V1 impedance is unknown. \$\endgroup\$ Sep 15, 2023 at 10:37
    \$\begingroup\$ As long as the source impedance (Z_V1 + Z_C1) is reasonably small compared to R3. When the source impedance approaches R3 the AC signal gets attenuated. \$\endgroup\$
    – jusaca
    Sep 15, 2023 at 11:18
