I am working on a DC load circuit and have put together a simple configuration based on templates available online. As you can see in 3rd image attached, I am noticing a small ringing in the load circuit measured at R1 which is a current sense resistor. I am assuming its being generated from the OPAMP not being able to stablise quick enough and so I tried different random solutions like adding 10 pF capacitor between MOSFET base and ground however I am unable to completely get rid of the ringing.
Can anyone suggest a methodological approach to stablise the opamp and remove this ringing?
Thanks,
Edit: Final schematics with added RC filter on 2nd stage opamp to filter out ringing. Adding to original post in case anyone's looking for similar solution:
