I'm having issues with my current AVR-C project that runs on an ATMega328p. After issuing the sleep command the chip wakes up again immediately. I want to wakeup with an external interrupt, but while trying to find the source of the issue I disabled them as well, expecting the IC to stay in power down forever.
void system_sleep() {
    // adc disable
    ADCSRA = 0;
    wdt_disable();
    cli();
    // EICRA = _BV(ISC10) | _BV(ISC11);
    // EIMSK = _BV(INT1);
    EIMSK = 0;
    EICRA = 0;
    set_sleep_mode(SLEEP_MODE_PWR_DOWN);
    sleep_bod_disable();
    sei();
    sleep_cpu();
    sleep_disable();
    // disable external interrupt
    EIMSK = 0;
    EICRA = 0;
    adc_init();
    wdt_enable(WDTO_1S);
Any ideas what could cause that? Is there an easy way to check what wakeup source triggered sleep to end?
  • \$\begingroup\$ Any interrupt will wake it. This is one function, we have no idea what other sources might also be enabled; the simplest assumption is that there are others. Trigger source is recorded by interrupt flags, and in turn CPU branching to the respective ISR if used. \$\endgroup\$ Sep 19, 2023 at 1:27
  • \$\begingroup\$ For power down (according to the data sheet) only INT, PCINT and I²C, assuming I understand it right. I'm not using either of the latter two in the project. The only other interrupt vectors are a timer and the adc, which also both are disabled \$\endgroup\$ Sep 19, 2023 at 1:45
  • \$\begingroup\$ When you do SEI, any active interrupt condition triggers on the next instruction. If you actually want it to sleep, you should clear the interrupt flag register before doing SEI \$\endgroup\$
    – david
    Sep 19, 2023 at 2:32
  • \$\begingroup\$ @david do you mean the external interrupt flag register EIFR? I gave that a go and it didn't help \$\endgroup\$ Sep 19, 2023 at 3:26
  • \$\begingroup\$ I was just thinking generically of the SEI/Sleep sequence. What interrupts have you enabled? Maybe TXC bit (UART register)? \$\endgroup\$
    – david
    Sep 19, 2023 at 5:15
The solution to the problem is not very exciting, as it was me simply overlooking something and for some reason didn't see it staring at the code for hours. I was simply missing a call to sleep_enable. The following works completely as expected.
cli();
sleep_enable();
sei();
sleep_cpu();
sleep_disable();
    \$\begingroup\$ Please put a green check mark in this answer, as it will be useful to others who have this kind of problem. Thank you. \$\endgroup\$ Oct 19, 2023 at 0:13
    \$\begingroup\$ Thanks, I completely forgot about that \$\endgroup\$ Oct 20, 2023 at 0:36
