I would like to build a small Battery Management System (BMS) using an ATmega406 and then maybe use an Arduino Uno to show information about the cells on a computer or a small LCD.
Here's a white paper about it: Battery Management System Atmega406 summary
Anyone knows a good site where I can read about the SMBus and what tools I need on a windows computer to use it?
    \$\begingroup\$ SMBus is a subset of I2C. \$\endgroup\$ Sep 2, 2013 at 15:19
  • \$\begingroup\$ That would suggest that the answer is yes \$\endgroup\$ Sep 2, 2013 at 16:14
In my opinion your best bet would be to use Atmel Studio 6.
And here you can find details about the Atmega406 itself
http://www.atmel.com/Images/Atmel-2548-8-bit-AVR-Microcontroller-Battery-Management-ATmega406_Datasheet-Summary.pdf
  • \$\begingroup\$ I gonna try out Atmel Studio 6 now. What hardware do I need to connect my computer with the atmega406 ? Can I use something as cheap as this: amazon.de/Programmer-herunterladen-Netzteil-Atmel-ATMega/dp/… ? And yeah: I am totally new to microcontroller programming. I only worked with an arudino uno for two weeks or so \$\endgroup\$
    – UtzUni
    May 5, 2013 at 14:32
