I have a project that has a PCB housed in a metal enclosure. The PCB is powered by a USB-C connector. Power input is 20 V DC @ 4 A max. Power is sourced from an isolated AC/DC wall wart adapter. The PCB contains a Wi-Fi module, so I have put a cutout window in the enclosure, which will be replaced with plastic.
My current intention is to leave the PCB isolated from the chassis by using nylon stand-offs and make a plastic housing shell for the USB-C connector cutout.
Considering the following:
- chassis is not used for electrical purposes elsewhere
- safety
- common mode noise
- EMC
- static build up on chassis
- effect on Wi-Fi antenna
- the end device will go EMC testing
- consumer use product (non-portable)
Do I need to tie chassis to GND of the circuit? Are there any other things to consider before deciding?
