Can someone explain exactly when the STP08DP05 clocks data into the shift register and when data appears on the output?
In the datasheet (p. 10) the truth table is more confusing than helpful for me.
I was under the impression that OE and LE were asynchronous. I.E that I could use LE after I had clocked in data to make the internal state appear at the output and that I could PMW the OE to dim the outputs. However, the datasheet only has entries for state changes on clock edges.
How is the truth table meant to be interpreted?
