I want to derive the input impedance of this JFET circuit :
What is the method in order to derive the input impedance of this circuit?
here is the small signal but I haven't been able to deduce the equation of the input impedance
by neglecting output load :
Zi=Vin/i
i=(Vgs+gm*Vgs*R3)/R1
Vin=Vgs*(1+gm*R3+gm*R4)+i*R4 = Vgs*(1+gm*R3+gm*R4)+(Vgs+gm*Vgs*R3)/R1*R4
Zi=((1+gm*R3+gm*R4)+(1+gm*R3)/R1*R4)/((1+gm*R3)/R1)
There is something wrong with these equations but I can't see my mistake...
  • \$\begingroup\$ Here you will find the answer electronics.stackexchange.com/questions/372071/… \$\endgroup\$
    – G36
    Sep 23, 2023 at 15:32
  • \$\begingroup\$ You have to draw the equivalent circuit for incremental signals at the center of the band . Once this is done, analyze the circuit and find the input impedance by applying a test voltage source to the input. \$\endgroup\$
    – Franc
    Sep 23, 2023 at 15:33
    \$\begingroup\$ "derivate" is a result of a calculation. I believe you want to "derive" the input impedance. Have you thought about using a simulation tool? \$\endgroup\$
    Sep 23, 2023 at 15:40
  • \$\begingroup\$ We see that R1 resistor current determines the Rin. Rin = Vin/I_R1 So we need to find the I1 resistor current. JFET gate current is 0A. So I_R1 current is: $$I_1 = \frac{V_{IN} - V_{OUT}\frac{R_4}{R_3 + R_4}}{R_1}$$ Additionally, we know that \$V_{OUT} = A_V * V_{IN}\$ So if we combine all the information we get Zin is equal to $$Z_{IN} = \frac{R_1}{1 - A_V \times \frac{R_4}{R_3 + R_4}}$$ \$\endgroup\$
    – G36
    Sep 24, 2023 at 7:53
  • \$\begingroup\$ I see that you did manage to find the Zin. Your equation is correct. Good job. \$\endgroup\$
    – G36
    Sep 24, 2023 at 12:44
You can derive the input impedance as suggested in the links in the comments. Deriving a useful function over frequency is more involved, thus, using a simulator is a more expedient method. The accuracy of the simulation depends on the accuracy of the transistor model.
The simulation below shows how you can do this in LTspice. enter image description here
The red trace is the input capacitance which is about 2.1 pF which affects the impedance (|Z|) above 5 kHz.
  • \$\begingroup\$ qrk Thanks a lot for your reply, you're right the result is 6Mohms but I can't find it by equation from my small signal model \$\endgroup\$
    – exolune
    Sep 23, 2023 at 22:05
  • \$\begingroup\$ See the update in the first post for equations and small signal model \$\endgroup\$
    – exolune
    Sep 24, 2023 at 0:14
