I find the problem given interesting in a few ways:
- For questions I've seen here, it's unusual to see a specific mention of a "20%" variation in parameters. I take to mean
BJT parameters
as E12 resistors don't vary that much and, while capacitors do, their values in a circuit like this only need to be large enough
to serve the need.
- Both the source and load impedances are included. I don't see that happen as often as I'd like.
- It's unusual for me not to see an explicit gain specified. But there are other factors that can dictate this. (Such as, for example, the voltage across \$R_{_\text{E}}\$.) So no worries, in particular. You mention "I have previously discovered..." and there suggest \$\mid\: V_{R_{_\text{E}}}\mid\:=1\:\text{V}\$, so I'll discuss that, too.
Let's start with #1; the 20% variation in parameters of the BJT. There are three parameters that matter here, \$\beta\$, \$I_{_\text{SAT}}\$, and \$V_A\$. All of these alter the DC quiescent operating point. But only \$I_{_\text{SAT}}\$ matters enough to cause anything near 20% variation.
Some thoughts:
- The collector current is in the vicinity of \$1\:\text{mA}\$. While the high-\$\beta\$ BC547C device does have an attending crappy \$V_A\$ (tends to go hand-in-hand) of around \$50\:\text{V}\$, this means an added \$50\:\text{k}\Omega\$ across the collector-emitter and given that your collector resistor is likely to be more than 50X smaller, it's just not going to impact things by 20%. (It will slightly reduce the resulting gain.)
- \$\beta\$ is really high, as stated at \$\beta=400\$. (This is kind of low for the
C
part with the Fairchild datasheet saying that the minimum is 420.) And you are permitted a fairly stiff divider pair because of the allowance of \$18\:\text{mW}\$. So a 20% change in base current, which will be less than 2% of the divider pair current, won't upset the biasing by more than 2%. Likely less. That said, \$\beta\$ variation is almost always greater than 20%. So a strong argument can be made that the lesson's limiting of 20% is unrealistic here. So perhaps \$\beta\$ should be kept in view. But the problem statement says "no." So either I go with that or disagree with it. A choice must be made. My choice is to look at it and let you decide.
- Now we get to \$I_{_\text{SAT}}\$. Again, here, a 20% variation will only account for \$V_T\cdot\ln\left(\frac{1+20\%}{1-20\%}\right)\$ or about \$10\:\text{mV}\$ on \$V_{_\text{BE}}\$. That's around 1.5% variation. So that's not going to qualify.
- But again, \$I_{_\text{SAT}}\$ variation is a lot more than 20%, part to part, too. 100% or more. So on this last point I have to think they meant to directly address \$V_{_\text{BE}}\$ with only an indirect implication for \$I_{_\text{SAT}}\$. Taking that as their purpose then this can significantly impact the biasing of \$R_{_\text{E}}\$ and therefore \$I_{_\text{Q}}\$ and therefore the circuit itself. However, we run into another problem because of the implications of variations on \$I_{_\text{SAT}}\$, as this makes a claim that such variation is over four orders of magnitude change. And that also doesn't happen.
So what does all that mean when someone says to account for a 20% variation in parameters? Especially when taking a cargo cult
value of \$V_{_\text{BE}}= 700\:\text{mV}\$ (which a quick look at a datasheet confirms) and then from there claiming \$560\:\text{mV} \le V_{_\text{BE}}\le 840\:\text{mV}\$, when a more likely range might be \$680\:\text{mV} \le V_{_\text{BE}}\le 720\:\text{mV}\$?
Well, perhaps the answer is about temperature variation of \$V_{_\text{BE}}\$, which can vary by a couple of millivolts per Kelvin (with varying rates of change depending upon the absolute temperature.) The writing above is trye when the temperature is considered unvarying. But adding temperature variation does matter. Here, assuming \$\pm 30\:\text{C}^\circ\$, then perhaps \$560\:\text{mV} \le V_{_\text{BE}}\le 840\:\text{mV}\$ might actually arise. So I'm thinking that the author is talking only about \$V_{_\text{BE}}\$ and including not only part variation but also all reasonable operating temperature variations, too.
Note that it takes all of these machinations just to figure out the meaning of #1 above.
How do you keep a circuit's operating point stable over such wide temperature variations? In this case, by increasing the quiescent voltage drop across \$R_{_\text{E}}\$. If it's large enough, then even \$\pm 140\:\text{mV}\$ variation won't matter much. The larger the voltage magnitude you can throw onto \$R_{_\text{E}}\$, the better (for a stable quiescent point, I mean.)
Since no gain is specified, you could technically make the circuit very stable! But I'll be reasonable.
There are many rules of thumb. One of mine is that only under the most dire circumstances may the BJT become even slightly saturated. This will mean that \$V_{_\text{CE}}\$ must never have a smaller magnitude than \$1\:\text{V}\$. But I prefer \$2\:\text{V}\$. This has to do with safety margins to avoid saturation, in some part, but also to avoid gain variation (distortion) over signal input variation. Again, the more I can throw at it, the better. But here, I'd start with \$V_{ _{\! \text{CE}_\text{MIN} } }=2\:\text{V}\$.
This means there's only \$4\:\text{V}\$ left over to split between collector and emitter resistors at the worst case temperature (at the hot end of things where \$I_{_\text{Q}}\$ is at its maximum value.) Given the \$280\:\text{mV}\$ I also have to reserve out for variation of \$V_{_\text{BE}}\$, I'd select a quiescent \$\mid\: V_{R_{_\text{E}}}\mid\:=2\:\text{V}\$ and leave the rest for the minimum drop across \$R_{_\text{C}}\$.
Power dissipation says that the total quiescent stage current cannot exceed \$1.5\:\text{mA}\$. Again, it's important to take temperature into account when reading specs like this. Given that it is a spec, it should be taken as a worst case spec. And this will be at the hottest temperature, which is where we will design at, leaving the room temperature quiescent dissipation to fall out to a lower value.
The following is based on the highest temperature in the range. So when I mention quiescent
I mean `quiescent at the highest temperature':
Start at the negative rail and add reservations and an allowance for half the peak-to-peak output that must be achieved. So: \$V_{_{\text{C}_\text{Q}}}=-6\:\text{V}+2\:\text{V}+2\:\text{V}+3\:\text{V}=1\:\text{V}\$.
Given the usual rule (cargo cult-ish
) that the biasing pair carry about 10% of the collector current, this means \$I_{_{\text{DIV}_\text{Q}}}=150\:\mu\text{A}\$ (or more.) But keeping \$I_{_{\text{C}_\text{Q}}}=1.3\:\text{mA}\$ will keep us under the dissipation limit and make the biasing pair just a little stiffer. Which is good.
Base current will also vary over temperature because both \$I_{_{\text{C}_\text{Q}}}\$ and \$beta\$ vary. Given that the recommended value you have is a little lower than the minimum I see on the Fairchild sheet, I'm going to just accept the value for the highest temperature in the range. So this means a base current of \$I_{_{\text{B}_\text{Q}}}=3.25\:\mu\text{A}\$.
From there we can work out the resistors:
- \$R_{_\text{E}}=\frac{V_{_{\text{E}_\text{Q}}}-V_{_\text{EE}}}{I_{_{\text{C}_\text{Q}}}\cdot\frac{\beta+1}{\beta}}= \frac{2\:\text{V}}{1.3\:\text{mA}\cdot\frac{401}{400}}\approx 1534.6\:\Omega\$. If we pick \$1.5\:\text{k}\Omega\$ then this might put us past the dissipation limit, except that I selected a slightly lower \$I_{_{\text{C}_\text{Q}}}\$. So should be okay.
- \$R_{_\text{C}}=\frac{V_{_\text{CC}}-V_{_{\text{C}_\text{Q}}}}{I_{_{\text{C}_\text{Q}}}}= \frac{5\:\text{V}}{1.3\:\text{mA}}\approx 3846\:\Omega\$. If we pick \$3.9\:\text{k}\Omega\$ then this might push against the output signal range margin, except again that I selected a slightly lower \$I_{_{\text{C}_\text{Q}}}\$. So maybe be okay.
- \$R_{_{\text{B}_1}}=\frac{V_{_\text{CC}}-V_{_{\text{E}_\text{Q}}}-V_{_{\text{BE}_\text{Q}}}}{I_{_{\text{DIV}_\text{Q}}}+I_{_{\text{B}_\text{Q}}}}= \frac{9.42\:\text{V}}{150\:\mu\text{A}+3.25\:\mu\text{A}}\approx 61468\:\Omega\$. (Hold on that number, for now.)
- \$R_{_{\text{B}_2}}=\frac{V_{_{\text{E}_\text{Q}}}+V_{_{\text{BE}_\text{Q}}}-V_{_\text{EE}}}{I_{_{\text{DIV}_\text{Q}}}}= \frac{2.58\:\text{V}}{150\:\mu\text{A}}\approx 17200\:\Omega\$. (Hold on that number, for now, again.)
There aren't any E12 values for the base biasing pair and no simple multiplier can fix it. It is safer to cause the quiescent current to drop, than rise, given the dissipation limit. So I'll set \$R_{_{\text{B}_2}}=18\:\text{k}\Omega\$ and \$R_{_{\text{B}_1}}=68\:\text{k}\Omega\$. This will cause the biasing point to be slightly lower at the emitter and that will lower the quiescent collector current, slightly.
So the final circuit has \$R_{_\text{E}}=1.5\:\text{k}\Omega\$, \$R_{_\text{C}}=3.9\:\text{k}\Omega\$, \$R_{_{\text{B}_1}}=68\:\text{k}\Omega\$, and \$R_{_{\text{B}_2}}=18\:\text{k}\Omega\$.
From KVL: \$I_{_{\text{C}_\text{Q}}}=\frac{\frac{V_{_\text{CC}}-V_{_\text{EE}}}{1+\frac{R_{_{\text{B}_1}}}{R_{_{\text{B}_2}}} }-V_{_{\text{BE}_\text{Q}}}}{R_{_{\text{B}_1}}\mid\mid R_{_{\text{B}_2}}+R_{_\text{E}}\cdot\frac{\beta+1}{\beta}}\$. (Use Thevenin and KVL from base towards emitter to work this out.) So \$I_{_{\text{C}_\text{Q}}}\approx 1.05\:\text{mA}\$ at hot temperatures and \$I_{_{\text{C}_\text{Q}}}\approx 990\:\mu\text{A}\$ at low temperatures.
Gain should be low. There should be \$-0.062\:\text{dB}\$ attenuation on the input side (not much) and \$-0.692\:\text{dB}\$ attenuation on the output side. In between, the gain should be \$+6.59\:\text{dB}\$ due to the BJT CE stage (discounting the Early Effect, \$V_A\$, mentioned before.) All in all, about \$+5.84\:\text{dB}\$ or 1.96 (about 2X.) So to get the full output, the input source should present about \$V_\text{PK}=1.5\:\text{V}\$.
Let's check all this out with LTspice:
Looks about right.
And with signal added:
Which also looks about right.
