I designed a very compact 4 layer PCB that has many PCIe 2.0 differential pairs spaced in close proximity. In addition to the internal ground planes, I want to fill the signal layers with copper, and have vias between the pairs to serve as ground stitching and fencing.
I want to calculate what the spacing between the stiching vias should be (marked as d on the screenshot). Here are the steps I took to try and solve this:
- Found this formula to calculate the "approximate highest significant sine wave frequency component" of a square wave signal: $$BW [GHz] \approx \frac{0.35}{Trise [ns]}$$ Assuming a minimum allowable rise time of 50 ps for PCIe 2.0, the result is: $$BW [GHz] \approx \frac{0.35}{0.05 [ns]} = 7 [GHz]$$
- Calculated the wavelength of said frequency: $$\lambda = \frac{c}{7 [GHz]} \approx 42.83 [mm]$$
- Calculated the microstrip effective dielectric constant for Er = 4.4 as given by my pcb manufacturer for the prepreg material: $$Er_{eff} \approx 0.64 Er + 0.36 = 0.64 \times 4.4 + 0.36 = 3.176$$
- Divided the said wavelength by the square root of Ereff: $$\frac{42.83 [mm]}{\sqrt{3.176}} \approx 24.03 [mm]$$
- Divided the last result (how do I even call it?) by 8, as the "common rule of thumb" found on google suggests: $$d = \frac{24.03 [mm]}{8} \approx 3 [mm]$$
Is this the correct approach?
