I've been looking at the reverse polarity protection with a P MOSFET as part of a new PCB I am designing. My system is 12v. Most of the videos and diagrams I have seen, namely Afrotechmods YouTube & Components 101 use a P MOSFET alongside a zener diode and resistor. I believe the Zener diode is used to protect the P MOSFET from over voltage incase of reverse polarity.
I have found two sources which say I could connect a single MOSFET without a Zener diode/ resistor provided the maximum gate-source voltage exceeds the system voltage - Stack - 'throw away the zener' & Reverse Voltage Defender.
I was planning of using one of these Mouser IRF9540SPB which has a gate source voltage of - 20 V, + 20 V.
If I use a IRF9540SPB P MOSFET in a 12v circuit do I also need to connect a resistor and Zener diode or are these superfluous?
Adding the resistor and Zener is about protecting the MOSFET from voltage surges (should they occur). A surge of over 20 volts would cause the absolute maximum gate-source voltage to be exceeded and might damage your MOSFET.
So, how do you know if your supply gets the occasional surge? Answer - it will so, add the resistor and Zener. After all they don't take up much space.
If you know that the 12 volt supply can never create a surge greater than 20 volts then don't bother but, is it really worth it?
I believe the zenner diode is used to protect the P MOSFET from over voltage incase of reverse polarity
No, it protects against over-voltage of either polarity. In the conventionally connected scenario, it limits the gate-source to around 12 to 15 volts (Zener diode dependent). In the reverse polarity situation it acts like a diode and limits gate-source to about 0.7 volts.
  • \$\begingroup\$ Great thank you, that clears things up. The Zenner diode restricts the voltage, would a 1N4744A be suitable, it should restrict the voltage to <15v? What specs am I looking for in the other resistor? The component 101 website says to choose 100R-330R if there might be a sudden reverse voltage in the circuit. If that isn't the case anything from the 1k-50k. I am connecting my circuit to a car battery and this is where the reverse polarity can occur, it won't be an immediate so I assume a 1k or 50k resistor should be appropriate? Thanks again for the help, Sam \$\endgroup\$ Sep 24, 2023 at 20:28
    \$\begingroup\$ A 10 kohm resistor and a 250 mW to 500 mW Zener will be fine @tenniscelebrationparty --> if we are done here, please take note of this: What should I do when someone answers my question. If you are still confused about something then leave a comment to request further clarification. \$\endgroup\$
    Sep 24, 2023 at 20:33
  • \$\begingroup\$ Thanks Andy, that’s really helpful. What drives the decision on the wattage on the Zener diode? \$\endgroup\$ Sep 25, 2023 at 5:52
  • \$\begingroup\$ It only needs to be a low power Zener so, basically whatever you can get your hands on. \$\endgroup\$
    Sep 25, 2023 at 7:41
    \$\begingroup\$ For instance, if the maximum excursion above 12 volts was (say) 18 volts for a longish period and, the Zener voltage was 12 volts and, the series resistor was (say) 2 kohm, there would be 6 volts dropped across the resistor resulting in 3 mA flow into the Zener which, in turn, results in a Zener power dissipation of 12 x 0.03 = 360 mW. The resistor would dissipate 180 mW. \$\endgroup\$
    Sep 25, 2023 at 8:32
