A PCB that I am working on has a non-plated hole into which a press-fit threaded insert is installed to provide the mounting point for an M.2 SSD. As such, when the SSD is installed, the mounting screw is not electrically connected to the PCB.
A colleague mentioned that the SSD itself uses a plated half-hole on the edge, and I determined that it is in fact tied to GND on the SSD by verifying continuity between it and GND pins on the edge connector.
Should the threaded insert be installed in a plated hole that is electrically grounded?
