I want to implement a 4-bit parallel adder and subtractor using the same circuit while using a control input variable to switch between addition and subtraction. When my ctrl input variable is 0, I want the operation to be addition and subtraction when it is 1. When it is subtraction, I want to ignore the last carry out.
Here is my code,
module p4bitadd_sub( output [4:0]sum,input ctrl,[3:0]a,b);
wire c1,c2,c3;
fadder ad0(a[0],ctrl^b[0],ctrl, sum[0], c1);
fadder ad1(a[1],ctrl^b[1],c1, sum[1], c2);
fadder ad2(a[2],ctrl^b[2],c2, sum[2], c3);
fadder ad3(a[3],ctrl^b[3],c3, sum[3], sum[4]);
assign sum[4] = (~ctrl)&sum[4];
endmodule
module fadder(input a,b,cin,output s,cout);
assign s=a^b^cin;
assign cout = (a&b)|(b&cin)|(cin&a);
endmodule
My testbench,
module p4bitadd_sun_tb();
reg [3:0] a;
reg [3:0] b;
reg ctrl;
wire [4:0] s;
p4bitadd_sub dut(.sum(s),.a(a),.b(b),.ctrl(ctrl));
initial begin
ctrl=0;a=4'b1000;b=4'b0100;
#5
$display("Addition:");
$display("   %b%b%b%b",a[3],a[2],a[1],a[0]);
$display("  +%b%b%b%b",b[3],b[2],b[1],b[0]);
$display("  -----");
$display("  %b%b%b%b%b",s[4],s[3],s[2],s[1],s[0]);
ctrl=0;a=4'b0101;b=4'b0011;
#5
$display("");
$display("  -----");
ctrl=1;a=4'b1000;b=4'b0100;
#5
$display("Subtraction:");
$display("  -%b%b%b%b",b[3],b[2],b[1],b[0]);
$display("  -----");
ctrl=1;a=4'b0101;b=4'b0011;
#5
$display("");
$display("  -----");
$finish;
end
endmodule
My console output:
addition output
subtraction output
Any help is appreciated
The problem is in the p4bitadd_sub module. Your code has multiple drivers for the sum[4] bit.
One driver is the output of the ad3 instance:
The other driver is the continuous assignment:
When you have multiple drivers of a signal, you can have contention, and contention results in an x value in Verilog. x is the unknown value, or "don't care" value.
You need to change the code in the p4bitadd_sub module so that sum[4] is not driven this way. One way is to add a new wire (c4):
wire c1,c2,c3,c4;
fadder ad3(a[3],ctrl^b[3],c3, sum[3], c4);
assign sum[4] = (~ctrl)&c4;
endmodule
Output:
Addition:
   1000
  +0100
  01100
   0101
  +0011
  01000
Subtraction:
   1000
  -0100
  00100
   0101
  -0011
  00010
If you aren't already doing so, you should also dump waveforms for your simulation. Looking at waves can make it much easier to see values of internal signals than just $display statements alone. This is how I quickly narrowed down the problem with your code.
