Would like to know the difference between these two 4N35 optocouplers . They behave differently but cannot find what is related the "001Q" and "027Q" digit.
As commented, the different lines "001Q" and "027Q" are just date and assembly codes.
Image source: OnSemi 4N35 Optocoupler Datasheet
The two optocouplers should behave the same. If they don't, then either they are damaged, fake, being operated outside their specifications, or the difference is within specifications.
\$\begingroup\$ thanks. Will open another topic with different behavior problems eventually \$\endgroup\$– Ken90Sep 27 at 5:18
\$\begingroup\$ /Should/ behave the same within the operational ranges specified by the datasheet. It's definitely not safe to measure the parameters of one and expect others- even assuming they're genuine- to behave the same to the last microamp. \$\endgroup\$ Sep 27 at 9:34
the 4n35 to my knowledge has a few "edits" or versions since the first ed, from which it has been perfected. so the newer ones are likely more "linearized" in the optical current conversion. there's only a few "edits" of the old one 4n35. the newer ones are more linearized but also suffer a narrower slope.
behave differently
is a vague, useless description of observed behavior ... how do the two components behave? ... please add the schematic of the test circuit \$\endgroup\$
