I need to select between 10 different 164-bit buses using four-bit BCD (8421, unsigned binary). What is the most efficient way to do so?
Currently I have the following SystemVerilog implementation
case (bcdIn)
4'd0: muxOut = optionA;
4'd1: muxOut = optionB;
4'd2: muxOut = optionC;
4'd3: muxOut = optionD;
4'd4: muxOut = optionE;
4'd5: muxOut = optionF;
4'd6: muxOut = optionG;
4'd7: muxOut = optionH;
4'd8: muxOut = optionI;
4'd9: muxOut = optionJ;
default: muxOut = 'x;
endcase
where muxOut
and each of the "options" are 164 bits wide. The timing report for this snippet reveals a huge delay due to the fanout of the select lines (the digits of bcdIn).
Is there a more efficient way of selecting between large buses? Perhaps a tree construct of MUXes of some sort?
I am willing to code this by hand using assign
statements and the like, but if there's a way to infer faster logic using case
, I'm all ears.
muxOut
depending onbcdIn
? Depending on the expression, that might be faster than acase
. You could also try a lookup table, but I don't know if verilog can handle those. \$\endgroup\$
