I am trying to make the CQB50W12-72S12 120VAC input capable by adding a bridge rectifier into the design that is already called out in the application note (app note and data sheet found here: https://www.cincon.com/productdetail/CQB50W12.html).
See picture of what I have drawn up in altium: enter image description here
Because it is AC powered now I figure I need line to earth surge protection in order to get the same or better ratings for 61000-4-5. I looked up some littelfuse application notes on surge protection and saw that you can add impedance between surge clamping components for better coordination. I am going to start building what I have in LTspice but would like to get someone else's eyes on it for a sanity check.
I think that the mov's will help protect the bridge rectifier and remaining surge will be clamped by the TVS diodes that were recommended by the datasheet. I am just trying to achieve the same 2kV line to line rating and 4kV line to earth rating that the application note declares without completely messing up the EMI filtering.
    \$\begingroup\$ 120 volts AC produces a peak voltage of 170 volts but, the converter you are using is only specified for continuous operation up to 160 volts DC. \$\endgroup\$
    Sep 29 at 13:54
  • \$\begingroup\$ Is MOV/TVS to GND a good idea? It's not allowed for a number of installations / wiring environments / product types. \$\endgroup\$ Sep 29 at 14:19
    \$\begingroup\$ @Erv it seems a bit pointless to do any further analysis given the flaw on voltages. \$\endgroup\$
    Sep 29 at 15:14
  • \$\begingroup\$ @TimWilliams oh i did not know that, which installations is an mov to gnd not allowed? how do these installations protect against surges and achieve high line to earth surge ratings? \$\endgroup\$
    – user298907
    Sep 29 at 16:25
  • \$\begingroup\$ @Erv Well, maybe that's a solution. Though this drifts off the topic of design here, but it is nonetheless an issue engineers regularly have to deal with. Is there a reason you are required to use this unit, perhaps you were ordered to by a higher-up? If they aren't listening to any push-back on a matter that clearly several other professionals have identified is a critical, functional flaw, then chronic mismanagement may well be the underlying issue here, and there's only one sure way you can fix that: change jobs. \$\endgroup\$ Sep 29 at 18:01
I don't think you can get better immunity as the converter module already complies with 61000-4-5 Level-4 which is the toughest level already (unless a higher one is defined with Level-X by the manufacturer or yourself). Of course, this doesn't mean that you should rely on the converter module's surge protection so it's good to implement a separate protection for the AC-input-side components.
The datasheet on p.3 says the converter module complies with 61000-4-5. But the app note on p.14 (under Safety & EMC) mentions the requirement of external components in order for the converter module to comply with 61000-4-5.
The idea of placing TVS diodes for common- (D1, D2) and differential-mode (D3) surges is correct, however, the selection of the components doesn't seem to be. I don't know if you have a grasp of 61000-4-5's details, but apparently, you missed the fact that the currents during a surge, depending on the class/level of course, can reach hundreds of Amps.
What you need to do first is to check the standard and the required class/level for your application, then pick diodes having correct reverse stand-off and clamping voltages, and most importantly, an IPP rating (for 8/20 us) of higher than the class/level requirement. TVS diodes for surge immunity/protection generally mention what standards they are compatible with. This can be a good starting point. For example, if you have a look at the datasheet or product highlights of SMDJ180A you'll see that it's not compatible with 61000-4-5 as its peak pulse current rating is only 51 Amps.
As for placing MOVs for common-mode surge (across L-PE and N-PE), as Tim pointed out in his comment, you need to be very careful because, since the MOV will always be under mains stress (assuming N and PE have the same potential), a leakage current will flow through it to the earth which can cause self-heating (if not selected properly) and eventually initiating positive feedback and possibly destruction (i.e. heat causes higher leakage current, therefore higher self-heating, so higher self-heating causes even higher leakage current which causes even higher self-heating. This goes on until destruction). This may result in shock or even fire. Also, you may want to place another fuse on the N-side, plus you may want to cover the TVSs with nonflammable material.
    \$\begingroup\$ As I answered in a companion question, I strongly suspect they tested to EN50121, where the IEC 61000-4-5 surge is done through quite high resistance, not direct coupled. This seems to perfectly explain the choice of diode. \$\endgroup\$ Sep 29 at 16:27
  • \$\begingroup\$ @TimWilliams referring to your previous comment; littelfuse shows in this slideshow mov's in the configuration i have. Thats kind of where i got it from. psma.com/sites/default/files/uploads/… \$\endgroup\$
    – user298907
    Sep 29 at 16:55
  • \$\begingroup\$ @Erv For luminaires (street lighting), it seems? I don't know about that market specifically; I would guess there is some variation between jurisdiction (some may still be using constant-current loops(!), though with the adoption of LED fixtures I'm betting their days are even more quickly being numbered), but it's definitely not office or medical equipment, for example. \$\endgroup\$ Sep 29 at 17:00
  • \$\begingroup\$ @timwilliams please forgive my ignorance and lack of experience. Would industrial equipment allow for the use of 3 mov's arranged as I have? Or how would I look up this information? It seems to me that the 3 mov's arranged as such would clamp L-L and L-E surges and with coordination with the TVS diodes downstream could increase the surge rating the datasheet specifies. \$\endgroup\$
    – user298907
    Sep 29 at 17:07
    \$\begingroup\$ @Erv MOVs clamp the surge pulses to some extent as they behave like back-to-back avalanche diodes, so placing one across L-PE would seem a good idea for common-mode surges. However, placing anything (Y-cap, MOV, TVS, etc) across L-PE will increase leakage current. Your system will probably fall into IEC Class-I where shock protection is achieved with a protective grounding as well as insulation. So the ground leakage may become more of a concern here. Consider GDTs as well, either along with MOVs or as a replacement for them. \$\endgroup\$ Sep 29 at 17:16
