Its my first time using oscilloscope, I was trying to read output from AS1117 on an Arduino board, and this is what I get.
I was expecting square wave, but its nothing like it. Am I doing something wrong or is it supposed to look like this?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityIts my first time using oscilloscope, I was trying to read output from AS1117 on an Arduino board, and this is what I get.
First of all, you are measuring output of a DC regulator, so you should expecy a straight horizontal line at the set value.
Secondly, you seem to be powering your Arduino with a switch mode power supply. It will have some switching ripple zoomed in on that scale.
I'd expect that's pretty much what you should see.
At frequencies this high, it's most likely common-mode noise, transmitted between cables and connections that are not well balanced at radio frequencies.
Consider that the probe's ground lead has an equivalent inductance in the 100nH ballpark. What reactance does that have at this frequency? And what could that say about interference picked up by the scope probe? Suppose that the ground you are probing against has 1V peak at 80MHz on it: what would you then measure?
Looks like noise from an unconnected probe. Make sure you have ground on the probe connected to a ground on your target and the probe connected to the desired pin. Once you have that make sure you have your trigger and timebase set according to the signal you are trying to capture. If you are new to oscilloscopes I would suggest getting used to the connections and trigger control by connecting to the cal connections on the front of the scope. They provide a reference square wave.
