In transformer design, can someone help me understand how the no load flux is relevant to the transformer efficiency? What design parameters put constraints on the maximum core flux? Let's suppose I have a perfectly linear core material, what benefits I get by using higher flux density?
    \$\begingroup\$ the no load flux magnetisation (or flux density swing) doesn't change with loading. It all depends on the applied voltage, frequency and magnetising inductance i.e. \$v=L \ di/dt=N \ A \ dB/dt\$ (I'm sure you know what every parameter is/means). See here. constraints on the maximum core flux saturation flux density, losses, and some others that I can't think of at 11pm. \$\endgroup\$ Oct 2, 2023 at 21:44
  • \$\begingroup\$ Thanks. Ok so what I can gain in terms of fabrication cost or performance from a core material that doesn't easily saturate? \$\endgroup\$ Oct 2, 2023 at 23:50
  • \$\begingroup\$ @dambirambi Can use it at lower frequencies, for one. \$\endgroup\$
    – Hearth
    Oct 3, 2023 at 3:23
    \$\begingroup\$ @dambirambi you can get away with lower number of turns i.e. cheaper transformer as the copper (wire) is generally more expensive than the core. \$\endgroup\$ Oct 3, 2023 at 5:32
  • Power efficiency (as I presume you mean) is irrelevant on no-load i.e. efficiency is zero
  • No load flux is the only flux in the core even when the load is full-load
The core permeability (\$\mu_r\mu_0\$), the peak magnetization current (\$I_m\$), the number of primary turns (\$N\$)and the mean length of the magnetic field around the core (\$\ell\$). For instance, you might be familiar with this formula: -
$$B = \mu_r\mu_0\cdot H_{peak}$$
Well, to cut a long story short, \$H_{peak} = \dfrac{I_m\cdot N}{\ell}\$
So, you can work out what the peak flux density is and compare it against material curves to see how saturated the core might become.
  • Fewer turns means less copper loss
  • Fewer turns can mean avoiding issues with resonance (high frequency transformers)
  • Flyback-circuit transformers usually push the the peak flux density higher to get the power throughput whereas, regular-circuit transformers try to avoid this
