I made a pi attenuator with R1 = R2 = 1.2 MΩ and R3 = 1.45 MΩ. When supplying 5.2 V peak-peak at a range of 200 kHz-1 MHz, the rate of change for the attenuation factor is very large. What can I do to change that?
The intended attenuation factor was 10x. Experimentally, I am getting a range between 25x-50x depending on the frequency supplied.
