Circled in red are component through holes in a copper pour plane that are missing areas / don't have the copper poured completely around the via. Seen on tons of components both through hole and surface mount.
Why does the circled in red feature exist?
What is the feature called?
When should a designer add it to their designs?
When shouldn't they add it?
Does it matter whether the component is through hole or surface mount to add this feature?
How do you make this feature in altium?
