I can't get datasheets on these specific products, but I'm hoping there is a generic answer -- like is the length of the strip's internal wiring just causing enough of a voltage drop over the longer length?
These high density strips are 60 x 5050 SMD LEDS per meter, cuttable every 3 LEDS, or 2". I'm assuming these means the strip is constructed with 3 LEDS in series, these groups in parallel.
Why is a 3' strip rated for 14.2 watts and a 9' strip rated only ~2X at 27.2 watts? I no longer have a 9' strip, but when I did 3 x 3' strips in parallel, I can confirm through a killawatt that the power supply draws 48 watts. I expected ~27 watts due to the table claiming that 9' of LEDs would be 27watts.
