I'm trying to make an estimate for self-discharge rate of a typical small capacitor, such as 0.1 uF ceramic capacitor. Horowitz and Hill says "A better measure of loss at low frequencies is Dissipation Factor [...] the low-frequency loss mechanism is dielectric loss, not metallic resistivity." (Art of Electronics, the X Chapters, p36).
Kemet's datasheet for one of its most common parts C0805C104K5RACTU (0.1 μF, 10%, 50 VDC, X7R) says:
  • Dissipation factor: 2.5% 1 kHz 1.0 Vrms
  • ESR at 100 Hz: ~150 Ω (The ESR graph only goes down to 100 Hz.)
Can we use these values to estimate the decay time to say 1% of original? Following the capacitor charging rule, V = e-t/RC, I'm hoping for something like t ≈ 5RC, but don't see what to use for R.
Am I chasing rainbows or is there a simple way to estimate this?
A test circuit would be this: after C1 is completely charged, we disconnect from the charging circuit and measure the Voutput.
You should read the extended data sheet and look at the insulation resistance on page 14: -
So, I calculate the insulation resistance to be 10 GΩ using their guidance. This will determine the typical CR decay time (1000 seconds for a 100 nF capacitor).
What you linked to is what Kemet call their spec sheet.
Most typical multimeters will have a 10 MΩ voltage measuring input resistance and, this would be a thousand times lower than the insulation resistance = ineffective test.
Estimating self-discharge rate of ceramic capacitors from datasheet values DF and ESR
Dissipation factor is for AC scenarios and at DC, this would imply an infinite resistance because reactance would be infinite (\$D.F. = \frac{R_S}{X_C}\$). Insulation resistance takes over at very low frequencies because it becomes dominant.
  • \$\begingroup\$ Thanks as always for such a swift and helpful answer. I believe there's an error though in that note 2 for 0805 says "For Cap value 0.1uF (≤ 50V ) IR should be calculated under 500 mohms or 10GOhm", giving 5 GΩ, which matches that given in the spec sheet. I'm not sure why you're suggest measuring resistance; I'm speaking about the time until the voltage is at 1% of original. \$\endgroup\$
    – jonathanjo
    Oct 6, 2023 at 12:15
    \$\begingroup\$ OK, I missed that (not a big difference actually). I'm not suggesting measuring resistance; I'm explaining that using a DVM to measure discharge voltage would be ineffective because it's input impedance is highly likely to be far too low and, it will discharge the capacitor quite rapidly. \$\endgroup\$
    Oct 6, 2023 at 12:23
  • \$\begingroup\$ Thanks for clarifying, I didn't understand you meant discharging during the measurement. Yes, clearly you can't leave any ordinary meter connected. \$\endgroup\$
    – jonathanjo
    Oct 6, 2023 at 12:36
  • \$\begingroup\$ You also need to look at things like switch resistance when open, as it might well be in Gohm region. \$\endgroup\$
    – colintd
    Oct 6, 2023 at 15:55
  • \$\begingroup\$ @jonathanjo if we are done here, please take note of this: What should I do when someone answers my question. If you are still confused about something then leave a comment to request further clarification. \$\endgroup\$
    Oct 7, 2023 at 10:42
