The .equ directive is used to make constants:
.equ PERIPH_BASE, 0x40000000
This directive supports some operands like add, substruct or even shift:
.equ APB2PERIPH_BASE, (PERIPH_BASE + 0x00010000)
.equ GPIO_PIN_15,     (0x00000001 << 15)
I need to invert the value so I tried this:
.equ GPIO_PIN_15_INV,      (~GPIO_PIN_15)
In the disassembly window in the SMT32Cube IDE I see that my instruction
ORNS R0, R5, GPIO_PIN_15_INV
Changes to
08000166: orrs.w r0, r5, #32768  ; 0x8000
In other words, the value of GPIO_PIN_15 doesn't invert.
Is it possible to make an inverted constant with .equ? If yes, how? Where can I read about this possibility?
There are multiple way how to replace negation by other operations. One of them (in my opinion the easiest one) is XOR with full one pattern:
.equ GPIO_PIN_15_INV,      (GPIO_PIN_15 ^ 0xFFFF)
Test it yourself: https://godbolt.org/z/nKK4c8Wsf
Side notice: with 0xFFFFFFFF it will not work because ARM assembly is unable to encode 32-bit constants in the instruction word (which is 16 or 32-bit wide, so there is no space for such large constants).
