I've been trying to make an LTspice solar panel model based on this video: https://youtu.be/ox0UtYe4owI (2:45). This is the circuit that I got:
When I try to run a simulation I get an error:
"Error on line 2 : i§b1 0 n001 i=v(illu)/(1000*iph) Unknown parameter "i" Fatal Error: Missing current value for "B1" "
If I add curly braces (i={v(illu)/(1000 * iph)}) I get:
" Questionable use of curly braces in "i§b1 0 n001 i={v(illu)/(1000iph)}" Error: undefined symbol in: "v/(1000iph)" Error on line 2 : i§b1 0 n001 i=(v(illu)/(1000*iph)) Unknown parameter "i" Fatal Error: Missing current value for "B1" "
What am I doing wrong?
    \$\begingroup\$ It looks like "B1" is set to have a prefix of "I", making it an I source and not a B source. I sources cannot use the "I=whatever" syntax. \$\endgroup\$
    – Hearth
    Commented Oct 11, 2023 at 2:55
  • \$\begingroup\$ so what should I do? \$\endgroup\$ Commented Oct 11, 2023 at 4:10
    \$\begingroup\$ Turn B1 into an actual B source by changing its prefix to B. \$\endgroup\$
    – Hearth
    Commented Oct 11, 2023 at 12:19
  • \$\begingroup\$ Or use the correct symbol in the first place which is bi. Looks like you used current instead. \$\endgroup\$
    – Ste Kulov
    Commented Oct 11, 2023 at 14:54
You could use a "Voltage dependent current source"
"g" in the component list.
