I am not sure what the below symbols of a buffer looking symbol with a rectangle inside are:
This is from this datasheet here on page 11 of 13.
strange symbol in this IC block diagram that looks like a rectangle inside a buffer
It's a "Schmitt trigger."
A "Schmitt trigger" is a type of logic gate that provides hysteresis. It is used to convert a noisy input into a clean digital output. The Schmitt trigger has two threshold voltages: an upper threshold (V_T+) and a lower threshold (V_T-). When the input signal crosses the upper threshold, the output changes state, and it doesn't change back until the input drops below the lower threshold. This helps to eliminate noise and provides a stable output, especially for slowly varying or noisy inputs.
