In most derivations of the Maximum power transfer theorem the derivation is done using the relation of power :
P = i²R And on further derivation it comes out to be Pmax = Vth²/4Rth
If I derive the power from the relation p= vth²/Rth
It's clearly wrong My logic is as follows : The voltage across the load resistance is Thevenin voltage Vth , and it's resistance is RL but for Maximum power to be transferred, RL must be equal to Rth therefore the formula. Can anyone explain what am I missing here? (Actually I derived it intuitively in the exam, it turned out to be a blunder).
Your logic is flawed...
  • \$V_{TH}\$ is the equivalent open circuit voltage before you add any load.
  • When you add a load equivalent to the Thevenin resistance of the source, the terminal voltage across that load drops to half the original Thevenin voltage --> \$V_{TH}\$/2
  • Hence squaring \$V_{TH}\$/2 produces \$V_{TH}^2\$/4
  • \$\begingroup\$ Ah I get it, since the load resistance is equal to the thevenin resistance, the voltage drops half of it across the load and that squared gives the result. Thanks \$\endgroup\$ Oct 13, 2023 at 16:02
